![]() | Home > General > Suspension fault and yellow warning light |
Nico2104 Member Since: 10 Jun 2017 Location: Derby Posts: 56 ![]() ![]() ![]() |
Sorry forgot to mention it's a 2005 rrs 4.2 supercharged |
Any help would be appreciated. Thanks |
I can't help you, but a bump to bring to the attention of others. |
ohh it could be but then it is a land rover get a code reader or get someone to look at the codes could be valve block suspension bag ride height sensor or a wiring fault or a few other things |
Get codes read |
I am having the codes read next week but it hasn't done it since I posted which is strange. Literally 5 minutes of it beeping and doing what it did in the picture but then fine once driving and never happened since. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
If it happens again it's important to remember the order.
It definitely boinged 1st and then the rear driver's side went down. I might just change the ride height sensor as there not expensive or hard to replace so might be worth just replacing and clearing all faults. Cheers |
Well it is a Land Rover after all |
Trouble is they need calibrating so maybe best not to mess with it. |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 190 ![]() ![]() ![]() |
Are they not like the P38 and D2 ride height sensors, if you don't disconnect the battery and change the sensor, then they have to be calibrated. Disconnect the battery, change the sensor and then reconnect the battery and the system is no wiser , just picks up the sensor. |
don't know. |
I have a fox 910 diagnostics which does calibration on the suspension and other stuff so I think I might change it and then calibrate it myself. Then it will just be a waiting he to see if it does it again. Cheers |
