![]() | Home > General (L494) > Issues so far after 2 weeks |
Hedders007 Member Since: 19 Mar 2015 Location: Sussex Posts: 86 ![]() |
Morning,
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
1 I've never lost my Bluetooth connection but I use Android. (I do, however, frequently lose 3G and have to re-boot it from the 'Connections' option where I find mobile data has turned itself off). 2 My system often seems to 'forget' what I've got plugged in to the USB port, which in my case is a flash drive which I use for music (and that because the downloaded CDs on the hard drive can't be sorted or labelled even though they're all there, so I have to use USB instead). However, it invariably finds it if I unplug it and plug it in again. On my radio I get 'No Reception' quite often, when clearly there IS reception and you can get it back only by cycling the system. 3 My sat. nav. is always slow to boot up, but not to the extent to which you describe - unless you have some extremely short jorneys! ![]() 4 I've no experience of auto. access as I have deployable side steps so don't use it (on dealer's advice). However, it works OK manually 5 Can't answer that, as I live rurally so don't see many camera, and value the alert if I come across one (although it IS loud as you say!). 6 It took me ages to find out how to get front parking sensors to be on permanently, especially as the dealer said it couldn't be done. Otherwise, they are only on if you have previously been in reverse, and then just for the duration of that maneouvre. You can make them permanent in menu settings. They are, however, super-sensitive and frighten the life out of you when you aren't near an obvious hazard. (Where the supposed hazard is located is displayed on the graphics). If, however, you're referring to it not alerting even when it IS on, mine has only done that when reversing towards a fence with vertical bars, where it obviously was 'looking' between the bars and allowed me to get too close to open the boot. (Luckily, I got out to check!). Going forwards, it has twice failed to alert at all even when heading towards a solid wall. One thing I can say, however, is that the accumulated knowledge on here is better than my dealer's knowledge on the MY17 set-up (which isn't actually saying a lot!) so you may end up having to tell them what's wrong with it to get it fixed. The other clear fact is that LR are just not very good at car infotainment systems. (You would think that, being so slow in modernising their systems, they'd be able to benefit from developments already made by other manufacturers - they should reverse-engineer a few competitor's cars and find out how it's done!). |
paulmoz10 Member Since: 27 Apr 2017 Location: Nottingham Posts: 48 ![]() ![]() |
Thanks donny
Speed Cam alarm - long shot with this one as I don't have all these gizmos on my car but have you tried to adjust the volume rotary knob for the radio/ ICE while the alarm is sounding, some S the way you adjust the volume of the satnav directions? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
markymarkf Member Since: 08 May 2017 Location: Essex Posts: 143 ![]() ![]() |
How did you set up auto height access, i'm looking to do this on mine but cant figure out how to do it myself SVR Carbon Edition in Estoril Blue MY 21.5 P400e HSE Dynamic full on black with black pack, Meridian surround sound, Fixed Pano roof. Past MY17 SDV6 HSE Dynamic Yulong White and ivory leather. |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
See here: http://www.rrsport.co.uk/forum/topic48905.html MY2016 HSE D SDV6 - gone due to fuel dilution problems.
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 ![]() ![]() |
Not to thread hijack but my 17 SVR has got niggles with the infotainment system
