![]() | Home > Maintenance & Modifications > Upgrade door cards |
jimmybeituni Member Since: 14 Sep 2017 Location: bn16 2uf Posts: 4 ![]() ![]() ![]() |
do you know if the seats from a 2010 autobiography fit a 2005 rrs |
I think the price may put you off, to replace a door card on MY12 SDV6 is £830.00 inc VAT discounted price at Duckworth LR Parts. ![]() ![]() All this just for a damaged speaker grille (small hole) which can't be purchased separately only the whole door card! ![]() RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. Last edited by Johnski on Thu Sep 14 2017 8:48pm. Edited 2 times in total |
Cbr60rracer Member Since: 12 Aug 2017 Location: Norwich Posts: 8 ![]() ![]() ![]() |
Hi I recently done just this you just have to swap the original wiring onto seat frame. Takes a little while and only connection you need to make is the heated seats. Just cut original wire and connect with a double end connector and it's done . I just put some 2013 new leather on mine also, that's a pain but worth it. Regards ![]() |
Hi I managed to get a full second hand set of eBay £200 and looks so much better now. Slight variance on window switches which leaves a little gap but got some Matt chrome surrounds from china which stuck on and look pretty much original fitment. Your right about new prices so expensive like most things seem to be ![]() |
thanks for that i have just bought front and back seats and now panicking they won't fit the bolt holes are all spaced different but i don't think that will be a problem, did you have the same issues |
Well done managing to get a whole set, and not a bad price, did your speakers match and fit, as some have upgraded sound system fitted with a different grille layout? John
Hi
Hi Yes speakers were ok, only difficulty is wiring looms different on newer ones so the locking buttons on driver door become only decorative , still ok though as retain original on dash. |
