Home > In Car Electronics > Poor radio reception after fitting Pioneer SPH-DA120
R1CHD
United Kingdom 2005 Range Rover Sport TDV6 SE Java Black
Hi
My radio reception was perfect with the original head unit fitted but now I have fitted the pioneer unit I have poor reception, when I first fitted the head unit I used a 12v Fakra to DIN antenna adapter ( connected to the blue and white wire from Pioneer headunit) and then a standard Fakra to DIN antenna adapter, the adapter without the 12v feed seems better but reception is still poor, I used the in car Tec fitting kit to convert the wiring https://incartec.co.uk/Pages/Product.aspx?P=4872
I have also included pictures of both adapters used
any help would be great
Thanks
Post #535339 Thu Sep 14 2017 1:27pm
Leath31
United Kingdom 2008 Range Rover Sport 3.0 TDV6 Autobiography Adriatic Blue
Which model range do you have?
Post #535553 Sat Sep 16 2017 6:27am
R1CHD
Hi
It's a 2005 SE with no sat nav fitted but does have the Harman/Kardon system with amplifier under the drivers seat
Thanks
Post #535556 Sat Sep 16 2017 7:01am
