Home > Faults & Fixes > Strange noise...
R1CHD
United Kingdom 2005 Range Rover Sport TDV6 SE Java Black
Strange noise...
Good Moring
I bought a 2005 2.7 diesel yesterday and I have noticed a slight noise it's like a metallic grinding noise like the kind you get when you have a clutch release bearing worn or like when you have a broken bracket and you get that vibration / metallic pinking noise but it's only really noticeable when you are driving along and feather the throttle and with the window down , I can't get it to do it and idle or replicate it stationary, I'm 99% sure it's a broken bracket somewhere that's vibrating but just wondered if anyone had ever experienced this? The car has done 90k, thanks
Post #533887 Sun Aug 27 2017 6:57am
R1CHD
Ok so I've been under the car today and found that the heat shield fitted in the middle of the car between the exhaust silencer and propshaft was loose due to the washers pulling through the Tin plate I've removed the plate and found the propshaft center bearing worn/ rubber split, I'll replace both and see if this solves the noise
Post #533960 Mon Aug 28 2017 12:52pm
R1CHD
Right I've replaced the center bearing and the noise is still there. Anyone one got any suggestions?? Catalytic converter maybe??
Post #535247 Wed Sep 13 2017 5:57pm
Paddi
Corroded brake backplates flapping about? Easy enough to check if you can get it up on a lift. 2008 MY Java Black TDV8 HSE
Post #535250 Wed Sep 13 2017 6:18pm
R1CHD
Yeah Thays worth a look I'll have to get it on a ramp and see what's going on
Post #535262 Wed Sep 13 2017 7:32pm
One that happened to me was the EPB cable had come out of the hook that keeps it against the suspension arm. It's in the rear wheel well on both sides. It was rubbing on the wheel and made a similar noise to the one you describe. Easy to push it back in to the hook. 2012 SDV6 - it's missing a couple of cylinders
Post #535281 Wed Sep 13 2017 9:16pm
R1CHD
Ah ok thanks I'll check that, I'm hoping it's something simple and not some kind of horror story like a noisy camshaft chain or something
Post #535282 Wed Sep 13 2017 9:21pm
R1CHD
Thanks for the suggestions I've checked to find all ok, I am now thinking maybe its a pulley or belt tensioner has any one has issues with pulleys or a belt tensioner?
Post #535355 Thu Sep 14 2017 3:06pm
Citizen55
United Kingdom 2006 Range Rover Sport Supercharged Tonga Green
I have the same issue, it's subtle as hell, my my OCD knows the noise is there. I thought it was torque converter although I haven't had it checked out. Any luck solving yours? 2006 Range Rover Sport 4.2 s/c with Arden bodykit
Post #538259 Sat Oct 14 2017 10:49am
R1CHD
Hi Citizen55
No unfournetley not I’ve done a lot of research and the noise seems to be mainly on the 2005 vehicles with some reporting no fix but also no failure over thousands of miles, it seems to be a general trait of thevehicle but the genral thought for repair is either the torque converter or transfer box replacement but it seems people have replaced these components and it’s not always cured! My OCD also doesn’t cope well with the annoying noise but it’s a job to know what to do
Post #538261 Sat Oct 14 2017 11:03am
mikeyjones70
Morning
I have had the same issue ,same fixes ,changed the prop and still the same !
I have been advised it’s possible that’s it a diff noise ,the noise is like something catching .So annoying
Post #556877 Sat May 19 2018 7:19am
