Home > In Car Electronics > Any suggestions appreciated |
do you have codes at all or yellow warning lights at the time it starts or a red battery warning light |
Mon Sep 11 2017 6:00pm |
iannixon Member Since: 09 Oct 2016 Location: eastbourne Posts: 13 |
nothing....no flashing lights it all just goes dark. |
Mon Sep 11 2017 6:04pm |
How old is the battery |
Mon Sep 11 2017 6:10pm |
TBH not sure...ive had her for 1 year and always seems to be plenty oomph to get her started. |
Mon Sep 11 2017 6:14pm |
Can you test it at all with a multi meter across battery terminals with engine running and engine off |
Mon Sep 11 2017 6:39pm |
Will try after work tomorrow...what sort of voltage do you think I should expect to see? |
Mon Sep 11 2017 7:38pm |
Over 12 volts with engine off and over 14 with engine running |
Mon Sep 11 2017 8:02pm |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
I bought one of these when I was concerned about my alternator, found it very useful.
Mon Sep 11 2017 9:10pm |
Have checked the battery and alternator (mate lent me a battery analyser) the results I got were
Tue Sep 12 2017 5:21pm |
Battery seems not to bad i have heard on here about some loose connections to the rear of the instrument panel and it may be worth you checking the rear of the radio to make sure everything is plugged in correctly the noise you heard is the motor for winding in and out the hand brake shoes |
Tue Sep 12 2017 6:29pm |
How hard is it to get to back of radio. |
Tue Sep 12 2017 6:34pm |
Would it be worth getting new battery anyway? |
Tue Sep 12 2017 6:35pm |
Search on here radio removal not to hard to get out |
Tue Sep 12 2017 7:36pm |
Before pulling the dash apart would it not be wise to read the fault codes using a tool capable of reading land rover faults not just generics?
Wed Sep 13 2017 8:35am |
