![]() | Home > General > towing electrics panel is rusty |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Sounds normal
Every one i have ever seen has had surface rust around the tow electrics and recovery ring. Seems normal and my 13 plate has done the same.
Normal. Some folks remove bumper, de-rust with a phosphate based product, prime then paint with chassis black.
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
I did this, mine was very rusty behind the bumper so removed it, spent 3 hours removing surface rust then treated everything then Hammerite and Waxoyl. That was a year ago shortly after buying the car and it's holding up ok, no signs of rot reappearing at the moment but I'm not expecting a permanent cure. The rust will no doubt come back eventually.
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
Thanks for the info and reassurance guys, will assist when looking and buying. |
Sye 225 Member Since: 04 Mar 2015 Location: .. Posts: 9 ![]() ![]() ![]() |
Just a thought you could get a 2012 within your budget and you would have the 8 speed and electric tailgate then |
I would love a 2012 but looking around and pricing things up it would probably have in the region of 90,000 miles minimum on the clock if I'm lucky, |
Yeah this is true most will be higher than the 59k your looking at, i think the lowest 2012 i have seen recently and actually looked at myself was on 72k for 19995 in white. There are others but they are usually in the 80k+. |
Still plenty of 2012 upward models with under 50,000 miles available, 62 reg with Approved full warranty, just look on LR Used Cars. See link below, you may have to sort by ascending years, or do a new search.
True, but the cheapest on there is £25,000 which is well beyond my £20,000 budget and that is only an SE compared to HSE that I am after. The cheapest HSE is £28,000. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Sorry about that, I missed your price range, the second link down is for a HSE Lux at £28000 with 44k+ mileage, which is excellent value when you take in the full 2 year warranty, 2 year MOT cover, Half day off road course and 2 year full roadside and Home assistance etc. I'm sure they would come down £2-£3k on price, much better getting one with full history and the approved package if you can stretch your budget, it is a buyers market at present and once 5 years old they can't offer with the approved package so they are more likely to drop price to move them. John
