Home > Technical > Kick down not working correctly on 4.2 Supercharged
Wilson
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Evening all... I've had a good search but most posts are deisel related and solutions mostly EGR related, as mine is a 2006 4.2 Supercharged my problem certainly isn't EGR. Sooooo I can be cruising at 60-70ish and when I put my foot down hard past the kick down it doesn't drop gears at all for a good few seconds (feels like forever) I've only had it a week so not really sure how long it has been doing it, but my old TDV8 I had a while back never had this delay.
Regardless of S/H I am going to do an ALL fluids change in the next few weeks (I do it with any used car I buy) But I'm thinking this could be some sort of settings fault... for example on my M3 SMG to reset the gearbox settings you hold both paddles for so many seconds, is there anything similar on the RRS?
I have just received my IIDTool BT but haven't had a chance to use it properly and learn much from it yet!
Many thanks
Wilson
Post #534325 Fri Sep 01 2017 10:59pm
I think petrols do have egr.
Are you pressing the Pedal hard into the carpet?
Give sport mode a go. Simply more lever to the left. Don't move up or down.
Good for joining the motorway.
Post #534330 Sat Sep 02 2017 7:16am
Wilson
Really??? I have always related EGR to diesels!!!
Yep, all the way to the floor past the kick down click, I have used sport but honestly I don't normally!
Thanks
Post #534332 Sat Sep 02 2017 7:42am
Wilson
Good morning all,
I reset the transmission using the IIDTool thingy, and it appears to have resolved the issue so far, it hasn't had the long confused type delay since, although it does seem to take around a second to kick down (not in sport) I assume this is just how they are normally???
(Just adding my fix for future searches)
Post #534498 Mon Sep 04 2017 9:47am
Socast
The gearbox adapts to how you normally drive, so when you clog it and it's not kicking down quickly enough thats a sign that you normally drive the car quite sedately (always a positive) so the computer interprets it as an accidental press. Theres not really anyway around this other than driving like a nutter the whole time or having the engine re-mapped and throttle response tightened.
I personally kick across into sport mode before overtaking or doing anything daft as it automatically kicks down a gear and holds the revs higher Smile
Post #534511 Mon Sep 04 2017 12:15pm
yeah it's always smoother and quicker that you select the lower gear (e.g by moving it to over to sport) before you put the pedal down.
Post #534531 Mon Sep 04 2017 5:29pm
Socast
I wouldn't say it's smoother, it's just more predictable. When in drive, if I stomp the throttle sometimes it'll launch, and others it won't. Putting it in sport the car is in no doubts as to what you want it to do haha
Post #534532 Mon Sep 04 2017 5:42pm
Sye 225
United Kingdom 2005 Range Rover Sport TDV6 HSE Fuji White
if you've only had it a week i would say its more likely what socast has said. If the previous owner drove it nice and steady all the time, the computer would have this all logged still. So curing it with a reset with your tool makes sense as it would have deleted the previous owners settings Smile
Post #534534 Mon Sep 04 2017 6:22pm
