Home > Maintenance & Modifications > Fuel Leak |
Darren1966 Member Since: 04 May 2017 Location: Malton Posts: 6 |
Had same issue with my tdv8 it was the fuel filter seal not sat correctly some guy came out and something to the guy about the filter how to fit it correctly no issues since hope this helps. |
Mon Aug 28 2017 6:53pm |
Forgot to say had to take some bits off to see the leak |
Mon Aug 28 2017 6:58pm |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 |
thanks. That's what i was thinking / hoping, but have the car jacked up still doesn't give me the necessary space to manoeuvre. 2019 RRS P400e Autobiography
Mon Aug 28 2017 7:38pm |
Strip down around the filter as much as you can dry allaround the filter as much as poss get some one to start the beast & you should be able to see where it's coming from. |
Mon Aug 28 2017 8:34pm |
Fuel leak fixed. Turns out the hose from the injectors to the oil filter (??) had corroded and was leaking. Potentially could have been seen by the garage when they did the service.
Mon Sep 11 2017 3:23pm |
