![]() | Home > Technical > Battery drain |
Windymiller29 Member Since: 20 Mar 2016 Location: Staffordshire Posts: 2 ![]() ![]() |
A strange electrical fault has developed on my late 09 RRS. Something is draining around 5 amps off the battery when everything is switched off, suspension lowered and locked up.
Might not be at all relevant to you, but when my battery was going flat and drawing far to much current when all off, it ended up being the drivers door not double locking properly, but then started to try every few seconds, no alarms etc sounded, so not aware it wasn't locking. Once sorted all returned to normal. A strange fault from something you wouldn't be looking for.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
I was was think they maybe for the lights but forgot to check the diagrams. |
Thanks for the replies, but apparently it's the fault of the alternator after all.
