Home > General > All warning lights come on if parked on uneven ground |
Nico2104 Member Since: 10 Jun 2017 Location: Derby Posts: 56 |
Does anyone at all have any ideas what it might be. Cheers |
Fri Aug 25 2017 10:05am |
You need to get the fault codes read before we all start to speculate |
Fri Aug 25 2017 12:28pm |
Hi. They have been read and they are none. Like I say all lights go off and drives fine once restarted or if it is started on the flat. The other day I had my 2 rear wheels on the kerb and 2 on the road and the yellow suspension light came on but as soon as my 2 rear wheels were also on the road the light went off and was all fine. It just seems very strange how it does it. |
Fri Aug 25 2017 1:34pm |
Mighty strange as soon as lights come on then they should log that code and you should be able to recall it with a code reader what sort of code reader was used do you know |
Fri Aug 25 2017 1:40pm |
