![]() | Home > Wheels & Tyres > Damage to alloy wheels - will it get worse? |
Get use to it, Sports have kerb magnetic wheels. Best bet find a good paint shop, the paint is Land Rover Sparkle Silver. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Is that polished faces on those wheels? If so then do not leave them - I'm still suffering from that mistake.
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
The rims are the (two colour) OEM "21" 5 split-spoke ‘Style 507’ with Diamond Turned finish", similar to this.
Well being diamond turned it's the same as polished - water will creep and cause all the lacquer to peel off and corrode underneath as it goes.
Here is the result of neglecting a kerbing on polished or diamond turned wheels. Mine were't actually kerbed, this is just the result of a poor dealer refurb! This effect started within weeks, although these pics will be after about 5 months.
Thanks; Candle wax, or car wax (aka Auto Glymn)? |
PS; I've never been motivated by snazzy alloy wheels, but these came with the car. That said, quite why JLR fit such ludicrously delicate wheels to a car beggars belief |
I guess candle wax might do the trick if that's all you have lying around, but I was thinking a car wax, something like Autoglym. A day or two won't kill them, you just need to get them protected asap unless you plan getting them refurbished soon. It's not too bad yet as the road salt hasn't started being used - you can nearly watch them turn once that starts. I noticed mine were needing attention but was heading to work for 4 weeks, the weather temperature dropped while I was away and the road salt used, and that's why mine were so bad. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Easy answer then, blast and paint or powder coat them. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
