![]() | Home > General > Recall P017 symptoms on an 07 RRS supposedly 'not effected' |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
can you post a picture of the engine bay ?
hiflyer81 Member Since: 09 May 2014 Location: High Peak, Cheshire Posts: 13 ![]() ![]() ![]() |
I wouldn't know what the servo looked like, I'm not automotively technically minded, I just do a fair bit of research when I get an issue!!
Yes it would affect your vehicle (if your profile is correct).
Thanks bodsy. LR customer services said my car wasn't effected! I've got it booked in at a local independent LR specialist as I need a new intercooler hose, I've also described this problem to them and asked them to have a look. They changed my rear brake pipes for MOT in May, and it's only started doing it since then, co-incidence or not. How would I go about getting a VOSA inspection?
Done the vosa check on line. Ours starts with:
