Home > Technical > Advice please
Psh
Advice please
Hi advice needed please, jet washed engine yesterday and now has loads of faults, hdc, gearbox, etc, I've had it plugged in but it says can't read faults as no communication from the transfer case module, Changed Brake switch also today, do you think the module is shot? Tia
Post #533206 Fri Aug 18 2017 10:05pm
probably water in the tx box ecu which is behind the battery.
Remove from car and try and dry out slowly.
Post #533208 Fri Aug 18 2017 10:09pm
Psh
I have taken them off and got them drying
Post #533212 Fri Aug 18 2017 10:40pm
Psh
The green light on dash (low) went off when i took the module out and now refitted is back on and car is still the same, could it still be the module?
Post #533226 Sat Aug 19 2017 10:12am
Sounds like it, although don't know much about them
Post #533228 Sat Aug 19 2017 10:39am
Johnski
To late now but it even states in handbook not to pressure wash under the bonnet.
Just far to much electrical boxes and connections which can't handle the pressure, or water.
You can even damage paintwork with some of these units on sale.
Plenty of products to remove grease and oil without the need for soaking everything. Whistle John
Post #533230 Sat Aug 19 2017 10:47am
d-9
There's probably still water sat in some of the electrics, it takes ages to evaporate out. Jet washing under the bonnet is a terrible idea, there is a reason mechanics use steam cleaners to clean engines, and even then there is a big risk to the electrics.
I think you may be chasing electrical issues for a while
Post #533281 Sun Aug 20 2017 8:17am
