Home > Maintenance & Modifications > Steering wheel shake
Guyzer73 wrote:
Mikey,
I thought it was 38/42 when using the loaded vehicle figures? I found that the Sport has less steering wheel shake at this pressure. I'll give the 33/36 a try if you think that'll help but in my experience the lower pressure exasperated the problem... Confused
Guy
The high pressures are just hiding the early stages of the problem. 2012 SDV6 - it's missing a couple of cylinders
Post #531792 Mon Jul 31 2017 7:52pm
tonyg74
United Kingdom 2010 Range Rover Sport Supercharged Autobiography Java Black
Hi All, I'm having steering wheel shakes on my 2010 RRS S/C but only at speeds of 50-55mph. I've recently had all bushes replaced and wheels aligned. If it's the diff, would this be covered by my aftermarket warranty?
Post #532414 Wed Aug 09 2017 11:41am
Eaters
You could get the oil in the diff checked for dirt and grime.
Assume you've checked wheel balance Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #532438 Wed Aug 09 2017 5:25pm
