Home > Maintenance & Modifications > Door un-openable !
Paul_selby
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Fuji White
Door un-openable !
Evening all. I've had my rrs sc for just over a year now and touch wood not had too many major issues ! Just little niggly ones!
I've been away for the weekend and on coming home went to open the osr door from the outside......nothing . No worries I thought, I'll open from the inside.......nothing . There doesn't seem to be any "mechanical" resistance that there is when opening any of the other doors so could it be a latch or snapped link ? I'm quite technical so have no worries of investigating but would appreciate if anyone has a guide for removing the door card so as to avoid any broken/scratched trim bits !
Post #532346 Tue Aug 08 2017 8:12pm
adameverett
there are some good write ups on here and disco site on door card removal,
http://www.disco3.co.uk/wiki/Rear_Door_Latch_Replacement
taken from a post with some good links
http://www.rrsport.co.uk/forum/topic28424....=door+card
I have done the rear door card myself when the lock jammed shut. Card removal was straight forward, it was releasing the lock that was the pita Evil or Very Mad
I assume you checked the obvious and the child locks are still not on and you have tried the unlock button from the dash etc.
Post #532358 Tue Aug 08 2017 9:12pm
Paul_selby
Thanks Adam . Yes I've tried the door lock/unlock button on dash . I also sat next to the osr door as I pressed the lock/unlock on the fob. As for the child lock there is only me drives and I've not messed with anything . I'd nip out and have a look now but as it's raining I'll wait till tomorrow and see how I get on . Are the child locks activated from the side of the door ( where the actual latch is ) ? Thanks for the links Thumbs Up
Post #532359 Tue Aug 08 2017 9:19pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
My son had a similar problem with his car, turned out to be a snapped cable.
Post #532360 Tue Aug 08 2017 9:22pm
adameverett
Dont think it will be a snapped cable as both door handles fail to open the door. Inside and outside handles are connected at different points on the actuator.
If the actuator has failed your pretty stuffed at removing the actuator as its secured by 3 torx that are only accessed when the door is open. Big Cry
I had a OSR door lock fail, both handles would not release the locked state. Let hope its something simple if not you might find this useful if worse comes to it.
http://www.rrsport.co.uk/forum/topic45683.html
keep us posted what you find.
Post #532369 Tue Aug 08 2017 10:52pm
adameverett
dam double post
Post #532370 Tue Aug 08 2017 10:52pm
RRSRobC
I had this problem. I sat there pressing the unlock button on the fob whilst trying to open the door from the inside and eventually it opened. I was sat there for around 2 minutes doing this but it worked. I don't really know what the problem was but it's been fine since. 2007 L320 3.6 TDV8 HSE Java Black
2010 W204 C350 AMG Black
2007 E93 325i M Sport Black II
2004 E46 330ci M Sport Black II
Post #532380 Wed Aug 09 2017 7:48am
Paul_selby
Thanks for the info people. Weather permitting I'll make a start tomorrow morning , and will post an update .........hopefully a good one !!
Post #532426 Wed Aug 09 2017 3:06pm
Johnski
Best of luck Paul. Thumbs Up
John John
Post #532541 Fri Aug 11 2017 1:27am
