Home > Technical > 4.4 petrol sport, fan seems to be running all the time
Tom55
Hi recently ive noticed the engine seems alot noisier, now it was fairly intermittent untill recently where its always noisy, now today when stationary i investigated and the fan was running non stop, sounds very concerning.
Is it anything to be worried about or is it a common issue?
Thanks
Tom
Post #532294 Tue Aug 08 2017 11:17am
I thought they had a vicious fan, which is driven by the engine, and would be moving all the time.
Post #532317 Tue Aug 08 2017 5:27pm
geoffsnook
Your viscous van may be knackered there is a bi-metallic strip that when it heats up it looks the fan on and when its cooler it stops the fan spinning all the time so yes when its at normal operating temp it should not be spinning apparently you can actually hold it but would never recommend trying it Thumbs Up
Post #532328 Tue Aug 08 2017 7:14pm
Tom55
Thanks for the help, is it at all related to the air con? I only ask as i noticed it was on all the time but after i had turned off the engine etc and on the way home it was normal, no noise etc, the difference was i had the a/c on but didnt on the way back when it was fine
Post #532334 Tue Aug 08 2017 7:22pm
geoffsnook
The van will run more when air-con is on but get it checked if you can Thumbs Up
Post #532343 Tue Aug 08 2017 7:59pm
yes it will run faster with the air con on.
If it's very noisy it may need replacement
Post #532352 Tue Aug 08 2017 8:47pm
