![]() | Home > General > Supercharged 2010 front brake dragging? |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
I had a sticking calliper on the Shogun last year, I noticed there was more brake dust on one of the wheels than the others, also after a drive if I felt the wheel it was noticeable warmer than the rest and finally when the car was jacked up if I rotated the wheel by hand you could tell it had more resistance than the when checked against the opposite side. I tried cleaning all the slides up but when I tried to push one of the calliper pistons back in I found it had become stuck. In the end I fitted new calipers as they were cheaper than a new seal and piston kit. |
As said feel if one of the wheels feels warm if it does then that is the caliper with the issue |
nashvegas Member Since: 21 Feb 2010 Location: Atlanta, GA Posts: 14 ![]() ![]() ![]() |
Replaced the front calipers and all is well. Front left was indeed dragging. Not sure why, internal fault apparently. |
