Home > General > Black smoke |
R4zb3rry Member Since: 28 Feb 2015 Location: Leicester Posts: 43 |
Split intercooler hose is a likely culprit.
Mon Aug 07 2017 8:53pm |
The G Man Member Since: 06 Nov 2013 Location: Sunny South Wales Posts: 17 |
Had Similar issues with a discovery TDV 6...turned out to be injectors. Smoke was worse when vehicle had been idling for a while. Hope this helps. |
Racket Member Since: 04 Jul 2017 Location: Manchester Posts: 4 |
No loss of power and no warnings on the dash.
Mon Aug 07 2017 8:59pm |
360 Member Since: 02 Aug 2013 Location: kent Posts: 116 |
My sdv6. Used to smoke occasionally, I always put it down to the car only doing short journeys and getting choked up, then when accelerating hard it would cause the soot in the exhaust to be blown out , would be fine for a few months after clearing |
Mon Aug 07 2017 9:23pm |
As previously suggested by another member..intercooler hose may be the culprit..after advice from this site I checked that first on mine but it was ok...She smoked more at low speeds but was hardly noticeable when at motorway speeds. Huge clouds of smoke when sitting in traffic. |
Mon Aug 07 2017 9:40pm |
Mine doesn't smoke at all when driving or putting your foot down, just every now and again it's as if the engine coughs and a huge plume of smoke comes out the exhausts, it was that bad the car behinds headlights came on.
Mon Aug 07 2017 9:49pm |
They only smoke badly when you hoof them |
Tue Aug 08 2017 10:36am |
How long have you had the car/has it had a tuning box fitted these can make them smoke or when was the last time it was serviced air filter changed |
Tue Aug 08 2017 10:37am |
chi Member Since: 15 May 2010 Location: hampshire Posts: 49 |
E G R Valves ? |
Tue Aug 08 2017 10:51am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8933 |
We don't know what engine it has because the OP hasn't told us or filled in their profile. 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 08 2017 2:11pm |
I'd lay a bet it's an oil burner though |
Tue Aug 08 2017 3:44pm |
Yes, but which one...? 2012 SDV6 - it's missing a couple of cylinders
Tue Aug 08 2017 6:11pm |
One with a turbo |
Tue Aug 08 2017 6:26pm |
Right guys, had it checked for faults and not a one came up. My girlfriend drives this to work every day about 4 miles away and never goes over 30 or boots it, I've just been out in it and a bit of smoke came out when I first put my foot down but then nothing at all came out. We drove on the motorway and kicked it down 2 or 3 times and everything was great with plenty of power, I going to put it down to it needs a good boot at least once a week.
Tue Aug 08 2017 7:14pm |
