![]() | Home > General (L494) > Filters |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 ![]() ![]() |
I think it will be easy enough, it's on a sliding bracket and the fittings are easy off connectors. It looks like to you spin the base off, then slide it up. |
Just an update on the fuel filter. I filled up as per usual at my normal BP. Drove 250km, then the next day, a message comes up on the screen, "water in Fuel" with a message to see owners manual. Luckily when this message occurred, I was at a LR dealership for other duties and the mechanic took the fuel filter off and drained the contents. Low and behold, water in the filter. So I guess the system works, which is good news.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 ![]() ![]() |
So now the readers will understand the reason to carry a spare. I just finished a motorcycle ride from Wollongong to Cape York and I can tell you roadside assist is a long way off when you get to remote areas. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Totally agree Bails, did you find the location of the fuel filter in the V8? 2017 MY17 SDV6 SE |
Yes filter in the same position as yours. I still need to pick up a spare and will do in the near future. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
mees Member Since: 17 Jul 2009 Location: bru Posts: 45 ![]() ![]() ![]() |
When you replace the fuel filter do you need to bleed the system? Or is it plug and play? |
