Home > Maintenance & Modifications > Service done, host of fault codes cleared
Socast
If you disconnected the battery then the valve blocks are closed and the system won't try to keep the vehicle level. So one corner going down means that the leak is somewhere between that corner and the rear valve block.
By disconnecting the battery you're taking the compressor and air reservoir out of the equation (provided that your valve blocks are sealing correctly).
But yes you can access the compressor under the passenger side rear door, if you put the car in off-road height and pull onto the kerb you'll have plenty of space to access the compressor.
Post #531867 Tue Aug 01 2017 4:26pm
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
thanks. That's what i thought but wanted to be sure. need to wait for it to stop raining. Seems i also now have a fuel leak..... which the garage who carried out the service assure me it is not because of them doing the service.
somewhere at the back of the engine but they need to remove the windscreen wipers and the black masking to have a better look. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #532011 Fri Aug 04 2017 7:57am
Socast
Was it leaking before they did the service ?
It could be that they fuel filter is leaking (which may have been changed during the service and not refitted correctly), that's located under the vehicle above the front skid plate.
Post #532012 Fri Aug 04 2017 8:31am
Pakolainen
Wasn't leaking before, which is why i presumed it was first an oil leak.
Expected nothing less for them to say that it wasn't their fault.
I seem to recall the fuel filter was changed.
Really wish i had a place to tinker on the car and some suitable equipment to raise the car up.
Is the fuel filter easy to re-adjust, or does it need a 'pro' to do it?
cheers 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #532013 Fri Aug 04 2017 9:06am
Socast
If you put the car in off-road height and then jack the front up a little you should have enough room to get underneath and check the filter.
You will need to remove the skid shield, it's a pretty heavy lump when you're laying on the floor!
Take a look at this link: http://www.rrsport.co.uk/forum/topic27415.html
Post #532014 Fri Aug 04 2017 9:18am
Pakolainen
thanks. have started scouring youtube for instructional videos. Lot of variety on there. Just need for it to stop raining. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #532017 Fri Aug 04 2017 9:52am
Pakolainen
Alrighty. No torrential rain so went out and took the plastic cover off under the left hand rear passenger seat.
Didn't find i was expecting to.
Is the drier unit then located somewhere else or am i being a muppet.
Couldn't see the same set up as posted in other posts and the sites selling those. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #532148 Sun Aug 06 2017 9:41am
