![]() | Home > In Car Electronics > denso touch screen |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
They are called Fakra Connectors and they are colour matched i.e Brown will only fit Brown, however there is one colour which is universal and will fit all colours, it is a sort of blue/green probably called Aqua but that is a guess.
rostan242@gmail.com Member Since: 15 Sep 2016 Location: Alfreton Posts: 28 ![]() ![]() ![]() |
Thanks for the reply
It won't work as a reverse camera unless you cut the middle touchscreen cable to make it think it's a Range Rover. And you need to have reverse camera enabled in car CCf.
When I did mine I did use a GVIF unit as I also fitted a TV Tuner and the Rear Entertainment/DVD etc. on to the front screen as well, which I guess would explain why I never had to modify the screen at all.
It was just my idea of what to pay for "gvif" since it can be checked at low cost. 9-pound adapter
You'll soon get |
