Home > Technical > TDV6 top end build |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
I'd recommend autoreserve off ebay, who sell Jag 2.7 heads for £100 each |
Mon Jul 31 2017 6:55pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Thanks Andy K. I take it from a mechanical point of view that would be a straight swap, off with my heads and on with the replacements heads, would you agree? Anyone else out there have any advice i.e. previous guides or write ups of this specific job RRS 2.7 HSE Stornoway Grey
Mon Jul 31 2017 9:03pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
Hmm if the heads will need replacement then at least pistons will also need to be done. After all the only reason the head sget damaged is because the valves have been bashing the piston tops.
Tue Aug 01 2017 1:53am |
If pistons do require changing would a visible check be enough to determine this once the engine is taken to pieces? RRS 2.7 HSE Stornoway Grey
Tue Aug 01 2017 9:04am |
Calling out to DM I was hoping to get your valued opinion on such a topic RRS 2.7 HSE Stornoway Grey
Tue Aug 01 2017 10:50am |
Some people will say the heads should be skimmed, but a clean up and inspection with a straight edge maybe sufficient.
Tue Aug 01 2017 11:05am |
start on page 4 here
Tue Aug 01 2017 11:30am |
Thanks Andy K... yes I did think that about the head skimming part. As no doubt some people would have had there engine exposed to heat warping at some level and have had them skimmed, but hopefully not needing to go down that way after oil pump failure. I do hope the pistons don't require changing either, but I'm not 100% sure of this, would a visible inspection be suffice? RRS 2.7 HSE Stornoway Grey
Tue Aug 01 2017 11:32am |
would a compression test be the way to go just now, is this a better way to determine what is knackered? RRS 2.7 HSE Stornoway Grey
Tue Aug 01 2017 11:42am |
Just seeking clarification - when you say you had oil pump failure I assume you had the cam belt idler mount failure rather than your oil pump that is in the housing fail. So your engine never had oil pressure loss.
Tue Aug 01 2017 12:11pm |
Yes you are correct, tensioner mount failure on the oil pump casing.
Tue Aug 01 2017 12:42pm |
having got it all timed up and having tried to start it maybe worth continuing.
Tue Aug 01 2017 6:35pm |
When you say trying starting it may be worth continuing, what exactly do you mean?
Wed Aug 02 2017 7:50am |
