![]() | Home > Faults & Fixes > Normal height only! |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Hi, my 2007 2.7 RRS has been getting the dreaded 'bong warning' and yellow suspension light on with message 'normal height only'.
Hi Geoff, did as you suggested:
check the cylinder for any leaks with soapy water |
Ok, took cover off and sprayed everywhere with leak detector. Nothing!
Not long really if you put it up to off road height as soon as it's reached it in theory the compressor should then turn off and it should be the same from access height to normal and it will come on every now and then but after start up it stays on for a a few mins then there could be an air leak somewhere |
Or the compressor is no good |
Have a look here lot more info
rostan242@gmail.com Member Since: 15 Sep 2016 Location: Alfreton Posts: 28 ![]() ![]() ![]() |
I have a very similar problem After a few minutes shows me Normal height only.I suspect the compressor needs repair.I know I can fix it myself.
Any warning lights on |
As stated all LR genuine parts have a two year warranty, if in doubt get it back to dealer quick as you are running out of warranty. John
After a few minutes of starting up shows up warning lights on.And what's worse what happened now
Sounds like a new compressor is required but without the code not 100% |
Compresor I can repair myself I just have to find where it is mounted but I do not have access to a good diagnostic cable
Found errors from the computer
