Home > Maintenance & Modifications > Steering wheel shake
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Afternoon All,
Hope you're enjoying the F1 Very Happy
Anyway, I know this is a well known topic and I've suffered from it on the past. However, I've had the wheels balance properly (newest Hunter machine) and there where no vibrations at all.
Steering has been checked and all is good, 4 wheel alignment ditto but the cursed vibrations between 80-100kph are back Crying or Very sad
So what could this be? I've been told the shocks/ dampers are on the way out especially at the rear, could this result in the vibrations?
If not what else should I check.
Thanks is in advance.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #531671 Sun Jul 30 2017 12:50pm
Disco_Mikey
Tyre out of shape
Worn wishbone bushes
Wheel alignment
Warped hub flange
Does it wobble all the time, or only when braking?
Post #531673 Sun Jul 30 2017 1:21pm
Guyzer73
Thanks Mikey,
Ok so vibrations are minimal when cruising or accelerating. They are at their worst when rapidly coming off the accelerator or after/ during breaking and then remain.
On your list I don't think it's the tyres as they're new and filled with nitrogen? To avoid them loosing shape in the heat... Wheel alignment is also good as I got this done with the new tyres.
I'll get the garage to check the hub flanges and wishbone bushes.
What are your thoughts what I said about the shocks and dampers?
Post #531680 Sun Jul 30 2017 2:18pm
Disco_Mikey
Front CV joints, and possibly a diff fault too Thumbs Up
Presumably all 4 tyres are the same brand/size?
Post #531681 Sun Jul 30 2017 2:28pm
Guyzer73
Thanks again Mikey,
Yeah tyres are Pirelli all round. I'll get the CVs and diff checked out also, I have noticed a whiring sound coming from the rear diff I think l, especially on acceleration, not sure if that's related...
Post #531683 Sun Jul 30 2017 3:14pm
Are the tyres the same pressure across the axle? I've found that a mismatch of pressures can cause a vibration. 2012 SDV6 - it's missing a couple of cylinders
Post #531692 Sun Jul 30 2017 6:39pm
Guyzer73
Hi RRSTDV8, yep tyre pressure checked weekly always run 42psi all round.
Post #531696 Sun Jul 30 2017 7:07pm
Disco_Mikey
Should be 33psi front and 36 rear...
Post #531704 Sun Jul 30 2017 8:42pm
Guyzer73
Mikey,
I thought it was 38/42 when using the loaded vehicle figures? I found that the Sport has less steering wheel shake at this pressure. I'll give the 33/36 a try if you think that'll help but in my experience the lower pressure exasperated the problem... Confused
Post #531707 Sun Jul 30 2017 9:20pm
DEVON
Excuse my interruption (and ignorance) ' but what is a hub flange ?
The reason I ask is I also have a slight steering wheel wobble since fitting a new wheel bearing ?
Post #531708 Sun Jul 30 2017 9:22pm
BKHK
Guyzer
Back in 2008, I had the same problem and it was a rear diff, it took LR months to find the cause. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #531715 Sun Jul 30 2017 10:45pm
Guyzer73
BKHK, thanks for that I'll get he garage to check when the car goes in at the end of the month.
Devon, I believe the hub flange is as per the image below:
Post #531723 Mon Jul 31 2017 6:21am
squizzel
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
I had the hub give problems a few years ago on an x-trail. A garage replaced the bearing under warranty, and they warped the hub getting the old bearing out. They claimed it was ok but when I checked the run out of the hub it was oval. New hub cured it.
Post #531731 Mon Jul 31 2017 8:03am
Pufftmw
I have slight vibrations under braking but nowt I'm too worried about (at this stage).
But...
Sat the car up for the afternoon in Mid-France on Saturday, in the sun. It was about 27 degrees. Place was 1/2 mile from the A20, so coming down the slip-road and the wheel was shaking like a mad thing Shocked
Soon settled down to nothing. Never had heat deformation that bad before
Post #531738 Mon Jul 31 2017 9:15am
BKHK
With my current RRS (L320) there are a couple,of sections of freeway where I have a bit of steering shimmy but on most surfaces it's fine. I think that road surface does make a difference which is annoying as it's hard to diagnose. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #531753 Mon Jul 31 2017 11:51am
