Home > Technical > More codes, many error messages
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hi Folks
I've been having this issue come up at random since getting my RRS a year ago where the dash flags up that nothing works for brake assist, DSC, and lowers for safety etc.. The first time a year ago I was coincidentally near the dealer so they said it was the steering sensor so recalibrated,and all appeared ok for a month or so. Now it appears only every month or so but our mileage is low. I have tried calibrating the sensor several times with the GAP iiDTool but no difference.
Someone I know incorrectly bought an original LR battery for his FFRR which is the exact battery fitted to my RRS, so I bought this off him. It's virtually new only having jumped his RR a few times so I fitted this and the faults still appear, but I am aware a badly stored new battery is none better than an old battery. Initially I thought it was due to the battery as reported on here a lot, and also it seemed to happen shortly after having started the RRS. But it recently happened after having driven for about an hour while on holiday, and as I was towing a caravan I wasn't best pleased with it lowering 'for safety'.
The latest code scan is:
Model L320 - Range Rover Sport 2013
Vehicle scanned on 21 Jul 2017 10:18:02 am
IIDControl 2.9.4.5 Android - IIDTool BT V3.0 B2444
ABS-Brake Module
U0126-00 (E8 ) Lost communication with steering angle sensor module
( on 08-07-2017 10:16:44 at 70692 km )
U0132-00 (28 ) Lost communication with ride level control module
( on 08-07-2017 10:17:57 at 70694 km )
U0138-00 (28 ) Lost communication with all terrain control module
( on 08-07-2017 10:16:40 at 70692 km )
BCM-Body Control
CCM-Cruise Control
U0103-00 (28 ) Lost communication with gearshift module
U0415-81 (28 ) Invalid data received from ABS control module - Bus signal/message failure - invalid serial data received
U0418-68 (28 ) Invalid data received from the brake system control module - Algorithm based failure - event information
IPC-Instrument Pack
( on 11-07-2017 15:41:17 at 70967 km )
PCM-Engine SDV6
( on 08-07-2017 10:16:40 at 70693 km )
RLM-Suspension
TCCM-Transfer Case
TCM-Transmission 8spd
U0138-63 (28 ) Lost communication with all terrain control module - Algorithm based failure - circuit/component protection time out
Any idea's to go on? 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #531480 Thu Jul 27 2017 8:40pm
Disco_Mikey
All codes seem to stem from loosing comms with the ATCM
Try changing the code read in the IID, to include "Pending" codes
This has flagged up a few issues with me that would have otherwise gone unnoticed (MAF sensor issue being one)
Post #531482 Thu Jul 27 2017 9:17pm
insiorc
Thanks Disco_Mikey
ATCM - a quick google brings up All Terrain Control Module? I meant to post this when I was home when I could deal with it, but I'm away now for 4 weeks but will check again once I get back home. I wasn't aware of any "pending" codes setting, how do I do this or will it be obvious when I next check the codes?
Also I see the dates the codes flagged up but I'm sure I've had the faults again since then but maybe I hadn't reset them the previous time, does the codes just show the first date flagged? 13MY Range Rover Sport Autobiography SDV6 - mine
Post #531488 Thu Jul 27 2017 10:17pm
insiorc
So I've got home and figured the Pending codes can be set in the Advanced scan menu. Below is what I got this time, I do know the messages appeared once since writing the initial post, when my wife was driving.
Vehicle scanned on 26 Aug 2017 10:59:50 am
ABS-Brake Module
( on 13-08-2017 16:06:08 at 71967 km )
( on 21-08-2017 18:45:01 at 72050 km )
( on 13-08-2017 16:06:07 at 71967 km )
BCM-Body Control
( on 13-08-2017 16:06:11 at 71967 km )
CCM-Cruise Control
( on 13-08-2017 16:06:12 at 71967 km )
( on 13-08-2017 16:06:13 at 71967 km )
( on 13-08-2017 16:06:09 at 71967 km )
IPC-Instrument Pack
( on 13-08-2017 16:06:06 at 71967 km )
PCM-Engine SDV6
RLM-Suspension
TCCM-Transfer Case
( on 13-08-2017 16:06:06 at 71967 km ) 13MY Range Rover Sport Autobiography SDV6 - mine
Post #533855 Sat Aug 26 2017 10:20am
Disco_Mikey
Go into "ECU info" and see if the tool can find the ATCM Confused
Post #533859 Sat Aug 26 2017 1:34pm
insiorc
I went into ECU info and it found the ATCM.
Thanks 13MY Range Rover Sport Autobiography SDV6 - mine
Post #533862 Sat Aug 26 2017 2:10pm
insiorc
At the moment everything is working as it should, I have the iiDTool in the RRS all the time so would it be of any benefit to try finding the ATCM ECU next time it happens? 13MY Range Rover Sport Autobiography SDV6 - mine
Post #533863 Sat Aug 26 2017 2:13pm
