Home > Maintenance & Modifications > Door Mirror Lamps - Is the Wiring There
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
My 2010 TDV8 does not have door mirror lamps which come on when you unlock the car. I have some very thin flush mount Hella LED lamps which will fit under the mirror and only require a small rectangular hole to be cut to fit them.
Is it likely that my car has the wiring for the door mirror lamps. It seems to have a lot of redundant wiring for options that it is not fitted with and I cant believe that Landrover had a different loom for vehicles fitted with door mirror lamps.
Post #531107 Mon Jul 24 2017 2:37pm
Socast
The wiring may not be inside the mirrors, it may be easier to buy some new mirros that have the puddle lights already fitted. They should be a straight swap, but as you say, the wiring loom upto that point will have the feed for the puddle lights.
I've fitted these to mine: https://tinyurl.com/yddt8r7u
The holder needed to be adapted slightly to take the panel, but they make a massive difference.
Post #531112 Mon Jul 24 2017 3:25pm
Fit a pair of RRS2 Mirrors they make quite a nice upgrade, you also get a puddle light with a logo in it.
Straight swap, just have to modify indicator wiring simple enough just connect side repeater wire to mirror wires, may have to update CCF files, I did on mine but I have surround cameras which have the puddle light integral in camera so had to tell it different.
Cheer
Post #531156 Mon Jul 24 2017 10:04pm
Johnski
My puddle lamps have RRS outline plus words Range Rover.
I assume that's been done as after fit on dealer repair? John
Post #531175 Tue Jul 25 2017 11:22am
