![]() | Home > Technical > 2012 Tailgate only opens with fob |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
You're unlocking the car first before trying the tailgate button? i.e. Unlocking the driver and passenger doors first? Naturally, this has to be done, or any TDH could have access to your boot |
Does it open with the button on dashboard? Visitor from fullfatrr.com
rodspink Member Since: 23 Jul 2017 Location: Angus Posts: 29 ![]() ![]() ![]() |
Lol. I actually just niped out and made sure I had fully unlocked the car and tried again.
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Mine opens with the button even if the car is locked, as long as I have the key with me. |
Yep, you see I've got an old RRS not blessed with keyless entry. Should have worked a little bit harder in my youth |
I guessed it was a key-less thing - like 'gesture tailgate' (when it works!), it wouldn't be much good if you had to unlock the car first I suppose! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Mine used to do that occasionally, fitted new switch to tailgate and now work works fine, funnily enough it only seemed to do it in hot weather. I am assuming you have the one piece tailgate being a 2012 car, if you fit a new switch I would suggest you get one of the kit's to mod it to close off the fob as well if the forum member still makes them up, it works brilliantly.
Excellent.
