Home > Faults & Fixes > Code 0406 Exhaust Gas Re circulation Sensor A circuit high
rayb22
Car has engine management light on and checked the code which is 0406 Exhaust Gas Re circulation Sensor A Circuit high. Also is the A circuit driver or passengers side.
Car is a Sport 2.7 TDV 6 08 plate and is still running ok
Was wondering if any one has removed the EGR before and cleaned up the valve.
I suspect that due to it the circuit being high that the internals are clogged up causes more amps to be used to operate the EGR correctly.
Could any one advise on any cleaner if the cleaning process is viable.
Thanks Ray
Post #530984 Sun Jul 23 2017 3:44am
Disco_Mikey
Just blank them Thumbs Up
Post #530985 Sun Jul 23 2017 5:48am
Bodsy
Site Sponsor
What Mike said. Thumbs Up
Whereabouts are you, if you fill your profile in (even as just a rough location) then that will help us help you. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #530988 Sun Jul 23 2017 7:21am
rayb22
If the EGRS are removed and blanked does the EMU need remapping to remove the warning light.
Also will removal not cause problems with emission test during MOT
Post #531034 Sun Jul 23 2017 5:57pm
rayb22
Mikey,
Post #531036 Sun Jul 23 2017 6:08pm
Disco_Mikey
Yes, the PCM needs a software patch, but easily overcome Thumbs Up
EGR is currently not tested for MOT purposes, so no issues come MOT time Thumbs Up
Post #531041 Sun Jul 23 2017 6:59pm
Green Spyghs
Re: Code 0406 Exhaust Gas Re circulation Sensor A circuit hi
Thanks Ray
@rayb22 if you remove it and stick it in the sink with a spot of fairy liquid, should be right as rain!
All the best friend,
G Thumbs Up
Post #531160 Tue Jul 25 2017 4:04am
Disco_Mikey
Really? Shocked Rolling with laughter
Post #531162 Tue Jul 25 2017 5:48am
