![]() | Home > Technical > Limp mode issues |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Doubtful the problem is the fuel rail/sensor. The fault does indicate fuel starvation so as you've fitted a new filter, next investigate for a possible faulty or worn fuel lift pump. |
Rangeboy Member Since: 17 Jul 2017 Location: Birmingham Posts: 7 ![]() ![]() |
Thanks. Does that require removal and test or is there a simpler way? |
Seem to recall someone on the forum managed to measure the fuel pump pressure with a gauge to determine a similar issue. Hopefully he'll see this and be able to help.
Thanks. |
Just remembered that you won't be able to tap someone up to help with an IID tool as they have to be registered to the car, unless someone has the Pro version which is usually limited to garages/mechanics.
Simon_scott_wilson1979 Member Since: 30 May 2017 Location: Stratford-upon-Avon Posts: 4 ![]() ![]() ![]() |
Hi. I'm having exactly the same faults and have done the same quick fixes that you have. Thought the fuel filter had solved the issue, but after three weeks of perfect running it's just come back.
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Sounds like a potential diesel injector fault TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
I ran some Wynns EGR3 cleaner through it today.........see what happens. |
I've since run some EGR valve cleaner through the air intake and had no more issues. Not saying I've cured it for sure......... |
