Home > In Car Electronics > Spotlight wiring |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
I am not a auto sparky but when I wired lights to my hi-beam on my car I just spliced into the hi beam line and ran it to a relay. The switched side of the relay was wired back to a fused ignition source (or you could use your switched source so you can still switch spots off when hi beam on )
Thu Jul 13 2017 6:22am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Simple 4 pin relay is the easiest way to do it |
Thu Jul 13 2017 7:09am |
Would you need a relay ?
Thu Jul 13 2017 8:15am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Thu Jul 13 2017 11:21am |
I actually tried the lamps today, turns out they're wired by standard to only come on with the high beams. So they're either off or come on with the high beams.
Thu Jul 13 2017 6:20pm |
