Home > Technical > 2009 3.0 TDV6 engine fault
Stretch
Hi all,
Long time lurker first time poster.
I'm in dire need with my RRS. 2009 3.0 TDV6 with 60K on the clock. Bought it last year knowing it had a brand new engine at 50K (although not sure why)
This started weeks ago, first start in the morning i had what i thought was a misfire for 2-3 seconds. The car was shaking violently. After about two weeks this had progressed to about 30 seconds. After this time it would stop and would not return the rest of the day at all.
A code scan reveled glow plug on cylinder 1 was faulty, so i replaced all 6 as a matter of course.
Vibration was still happening with no faults showing.
It's gotten progressively worse over the weeks as I've been working to fix it. It now will not start on the first press of the button. On the second press it will start but it's shaking like crazy for about 30 seconds, again however once it clears its perfect the rest of the day.
I have so far replaced:
6 x glow plugs
6 x injectors
Fuel rail pressure sensor
Low pressure fuel pump
Fuel filter
Suction valve on the high pressure pump
Today i carried out a compression check and cylinder leakage test which showed Censored all. Compression is good on all cylinders with no leakage (this was done when cold)
So I'm now completely stumped as to what to do next, the only thing i can think of is something is wrong with the high pressure pump ??
Anyone have some thoughts on what could be wrong ?
Thanks
Post #530025 Mon Jul 10 2017 7:36pm
Disco_Mikey
Has it recently has the cam belt and HPFP belt replaced?
Ignore that, new engine 10k ago Confused
Post #530045 Mon Jul 10 2017 8:56pm
Stretch
Yeah, at only 10k since a new engine i haven't stripped it down to inspect but as it's fine once settled im taking the timing as being ok.
Post #530046 Mon Jul 10 2017 9:06pm
Stretch
Hi all,
Just to rule it out i blanked out the EGR's today, which made the EML come on and resulting codes but no change in the starting behavior.
Post #530416 Sat Jul 15 2017 3:52pm
SRE
Spain
I think if it was my car I would drop it off with Mikey, he is only about 50 or 60 miles away from you. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #530450 Sun Jul 16 2017 8:19am
Disco_Mikey
Were they new Or used injectors?
Post #530458 Sun Jul 16 2017 10:06am
Stretch
Used, they came out of a Disco 4 same year same engine with lower mileage (that i had access too Whistle )
Said Disco 4 started perfectly with its own injectors and still starts perfectly with my injectors now in it so i ruled them out.
Post #530523 Mon Jul 17 2017 6:45am
Socast
Sometimes it's the simple things!
Have you checked for air leaks round the oil filler cap or PCV valve ?
Might be worth disconnecting the MAF sensor and seeing if that makes any difference.
Post #530730 Wed Jul 19 2017 11:38am
Disco_Mikey
What fault code reader is being used? Sometimes, the cheaper generic ones don't pick up all the manufacturer specific codes Question
Post #530732 Wed Jul 19 2017 12:04pm
Stretch
My own Snap on machine running the latest software, Ive scanned it with an Autel though too and that showed nothing.
Post #530748 Wed Jul 19 2017 5:47pm
Disco_Mikey
I'd be inclined to have it on an IID/Autologic/SDD, just to confirm it's not a manufacturers code not being detected Thumbs Up
Post #530753 Wed Jul 19 2017 7:19pm
Stretch
It's been on a Land Rover dealership machine, they picked up nothing. Sat in the dealership for 14 days then turned round and said the injectors needed coding Laughing Funny that as still doesn't run right after "coding"
Post #530760 Wed Jul 19 2017 7:52pm
