![]() | Home > General > Very squeaky suspension |
chopperchinn Member Since: 28 May 2016 Location: savoie Posts: 26 ![]() ![]() ![]() |
Hi, did you get to the bottom of your load squeak, I've the same problem seems after the car has warmed up, very load squeak!! front Reside
Suspension bushes. Take it to a decent garage who know these cars and they'll find it.... Visitor from fullfatrr.com
Yeah cheers, live in France |
Relayer Member Since: 05 Mar 2016 Location: Norfolk Posts: 6 ![]() ![]() |
Hi Chopperchin
Hahaha probably, I've had a look myself im i think its a leaking front airbag seal!! Still not sure though-frustrating |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
My suspension has started squeaking when going over bumps. From searching, sounds like it might be a dry bush?
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
my to dealer who said everything fine, took it to an indy who said front bushes worn so I replaced both front and back and got a different car back. |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
ARB bushes front and back they also called out a leaking ACE bar which dealer did under warranty |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 206 ![]() ![]() ![]() |
I'm in the south of France (Merindol) and just noticed my MY2012 squeaking also and only noticeable with the windows down or sun roof open at low speed. Will have my dealer have a look when I'm back, averaged a sweet 9.0l/100km on the way down and the price of fuel and wine makes this an easy trip..... 2018 Telsa MS
Thanks for that, I understand ARB's are not too much of a job, but the Dynamic response ARB's are really expensive. |
Mine were front bushes about £24 each rears about £16 each and about 2-3 hrs labour in total so not mega expensive. Thing that really |
Turned out to be a leaking front air bag, changed both front struts and noise has gone, unfortunately still getting the warning light suspension fault, normal height only aargh |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
