Home > Maintenance & Modifications > Changing the gear selector surround |
StateOfPlay Member Since: 24 Jun 2017 Location: Biggleswade Posts: 26 |
Tue Jul 04 2017 10:52am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
You have to remove to remove the complete console section as the surround it is held in with several clips and two screws, the screws are only reachable from underneath, if it wasn't for those it would just clip out separately. You can see at the front of the surround where the screws locate in your top picture.
Tue Jul 04 2017 11:07am |
It really isn't that difficult, flip out small DVD front panel, remove two Phillip's screws located under it, carefully release the panel where the ignition, clock and audio controls are you will need to pull it quite firmly to release the clips but don't yank on it to hard as there are electrical connectors behind it with not a lot of slack wire. Then to release the console start at cubby box end and gradually pull it up, it will take a bit off pulling and you will think it is going to break, once it is loose it will lift high enough to release electrical multi-plugs and just lift it out.
Tue Jul 04 2017 11:44am |
