Home > Maintenance & Modifications > EGR pipe bolts
triplemmm
EGR pipe bolts
I can't find anyone else thats mentioned this (apart from it being tricky) but how the hell do you get the 8mm bolts off of the egr pipes to put blanking plates in them?!
Got an EGR blanking kit today. managed to take off all the upper stuff, but no way could I get the angle or space to remove the two 8mm bolts at the lower end of each pipe.
There must be a simple to trick to this as so many people have done it. Please share!
(2006 TDV6)
Post #529422 Sat Jul 01 2017 7:45pm
can't remember, but have you tried a spanner to get them loose first ?
Post #529433 Sun Jul 02 2017 9:13am
triplemmm
???! Not sure you understand the question buddy.
you cannot get a spanner down there
Post #529434 Sun Jul 02 2017 9:17am
Oldandconfused
Socket on wobble bars? May need varying lengths to get the angles.
I must add the disclaimer that I've not done this myself, but I'm sure I have seen it somewhere, try a search on Disco3 forum.
Good luck.
Post #529435 Sun Jul 02 2017 9:38am
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
This video may help you. I know it shows full replacement but the access may help.
&list=PLG5imx3-4UILhR6NpQbAIAUbPwm_YTrrI&index=15
When I did it, I used a socket on a long extension for the accessible bolt and a ratchet spanner on the other one to get it started. Plenty of penetrating fluid helps too.
Post #529437 Sun Jul 02 2017 11:31am
triplemmm
Thanks all! Managed to buy a few other 1/4" extensions and universal joints to get in there. Very tight. Luckily the bolts were in good condition and came out no problem Thumbs Up
Post #529440 Sun Jul 02 2017 1:01pm
