![]() | Home > In Car Electronics > Replacement headunit options |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
Just a thought but
HS66 Member Since: 12 Apr 2016 Location: Surrey Posts: 38 ![]() ![]() |
The amp looks ok, on the headunit it's not displaying the volume when you turn the knob up and down so thought if the amp was at fault it would display the volume but there would be no sound?. |
It's usually the Amp, but sometimes the head unit.
Ah, mine is only an SE so doesn't have the nav screen. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Think it does that if there is no optical fibre network connection at the HU |
Mine also didn't show any input when I turned the dial up or down
Thanks guys, so something could have come loose at the back?, or sounds like it could be the amp?, I'm fine with buying either a new amp or headunit I'd just rather buy the one I actually need!.
star panels?
Sorry, was typing on phone, I undid the headunit from the facisia that was held in by star type Allen keys but it still didn't want to come out. |
you probably need to lift (read pry) away from the climate control panel |
