Home > Technical > Brake fault
Barlow1704
Brake fault
Hi there new to the site I'm having a problem with my brakes 2006 2.7 hse rrs, replaced the servo pipes and removed oil from the servo as the one way valve was faulty, my issue is how much oil if any should pass through the vac pump? Any help is appreciated
Post #528918 Sat Jun 24 2017 3:15pm
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Hi mate
The idea of the valve is to stop any oil migrating from the pump to the servo , so none is the answer . But it sounds like you have the same problem as many of us where the servo had oil in.
I suppose the vacuum is overcoming the valve and sucking it back. I've got two valves and a catch tank on mine as a trial 🤔
Post #528975 Sun Jun 25 2017 3:29pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
P017 recall
Post #528987 Sun Jun 25 2017 6:57pm
