Home > General > Advice required after seizing my engine. Car a right off :(
Tina04
United Kingdom 2005 Range Rover Sport TDV6 Java Black
After not putting enough oil in my pride and joy.... I have seized my enguine. After tons of diagnostic work.... I have been told I need to either buy a second hand.... been in accident.... no damage done type engine, or a reconditioned or recondition my own....
It's a 2005 model. Great condition... apart from the obvious. Lol
Another option would be to sell to a breakers yard or strip privately
Any suggestions.... I wouldn't even know what it's worth...
Help lol Question
Post #528709 Wed Jun 21 2017 8:32pm
Bodsy
Site Sponsor
Without an engine, you'd be lucky for £2k
Can get a Jag 2.7 engine for a couple of k Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #528710 Wed Jun 21 2017 8:46pm
Disco_Mikey
If you want rid of the car as is, id be interested Thumbs Up
On the other hand, if you want it repaired, I can also help out with that Thumbs Up
Post #528727 Thu Jun 22 2017 4:36am
garrycol
Australia
Were you changing the oil and didn't put enough in or dis the oil just get low?
If the former - did you change the oil filter? If so - did you put it in correctly - the little knob at the bottom has to go in its hole - if not, oil flow can be blocked or restricted causing oil starvation to the engine and failure.
I guess it does not matter now as it is too late but the cause may have been a crushed oil filter rather than low oil - after all with low oil, enough to cause a problem, the oil pressure light would have been on an pretty obvious. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #528737 Thu Jun 22 2017 9:31am
Tina04
I've decided to get rid as I have found another I've fallen in love with 😍
I've tried to pm you but not allowed as I'm a new member lol....
If you inbox me I can discuss what I've been offered already... 👍
Post #528762 Thu Jun 22 2017 5:08pm
Tina04
The oil just got low.... annoyed that the oil light didn't come on. It always has before on other cars if need be.. but it certainly didn't come on this time 😔😔
Post #528764 Thu Jun 22 2017 5:09pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
you'd better don't drive a car that needs caring. go for a lada or beatle. i know a guy/student time, who had een beatle ( Volkswagen) with a air cooled engine. He drove it for 10 years without ever checking or changing oil, it started every morning even in winter. Rolling with laughter RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #528765 Thu Jun 22 2017 5:13pm
Tim in Scotland
Tina you need 5 posts to activate PM's but if you add your email address to your profile then a button will appear on the bar below each post you make and that is usable with one post only. Nobody can read your email address in your profile BTW so you shouldn't get a heap of spam 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #528766 Thu Jun 22 2017 5:19pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Do Land Rovers need engine oil changing? I thought their self administering underbody anti-corrosion coating meant they just need the oil topped up, hence always fresh! Laughing It fairly stops my drive from rusting too Rolling with laughter 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #528775 Thu Jun 22 2017 5:48pm
Tim in Scotland
Embarassed I can vouch that "Land Rovers" do need oil in their transfer cases............. after driving the front wheels of my 90 into an overgrown and invisible drainage ditch with a big rock just were the transfer case sump was, I drove it more than 100 miles and thought "ummmm it really doesn't want to go very well" then the speedo stopped working just about 1 mile from the indie's workshop. I parked it in their yard, booked it in handed over the keys and said to fix it. Couple of weeks later I got a phone call asking what I had been doing as they couldn't shift the 90 without the aid of a very large fork lift and then a couple of winches and snatch blocks to get it on the ramp.............. there was a 1p piece size hole in the transfer case base, no oil in it and one seized up set of mechanicals inside - it had got hot enough in there to melt bits together and they set solid when everything cooled down. £1100 later it was back on the Scottish hillsides having fun and the transfer case works really well. Problem is that before the seizure my Defender NEVER dripped oil on the drive, now I keep a large sheet of cardboard under it when it is parked up to absorb the drips that it marks it's territory with. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #528779 Thu Jun 22 2017 6:32pm
Disco_Mikey
PM received Thumbs Up
Post #528783 Thu Jun 22 2017 7:19pm
garrycol
Australia
A friend had a 1800cc Toyota Corolla and he used to drive it until the oil pressure light came on and then topped up the oil - he thought the "oil Light" was like a low fuel light and was telling him it needed to refill the oil (like he would the fuel) - he did not realize it indicated low oil pressure.
Didn't not seem to damage the engine but certainly not best practice. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #528801 Fri Jun 23 2017 3:32am
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
It must be OK to drive until the warning light comes on, otherwise LR would have provided a dip stick, surely??!!!!!
Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #528820 Fri Jun 23 2017 10:43am
Tim in Scotland
2005MY had the horrid to read Citroen long wire old fashioned dipstick with some small yellow plastic beads on it to mark Max and Min points. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #528822 Fri Jun 23 2017 10:51am
Old Jock
Early ones have no oil level monitoring
Post #528831 Fri Jun 23 2017 12:49pm
