![]() | Home > My Range Rover Sport > DPF Regeneration |
There is a sensor that detects how clogged the DPF is and then forces a regeneration. I had a software update on my last car that caused the DPF sensor to burn out on a weekly basis until LR had investigated the problem........... Your regime for DPF cleaning almost complies with LR's requirements - you have to maintain the revs above a certain level not the speed. There is a warning light on the dash that will come on when you need to force a regeneration too. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
gnasher Member Since: 27 Jan 2014 Location: Cardiff Posts: 27 ![]() ![]() |
Thanks Tim. When I give it a burst I engage sport mode and keep the revs above 2k for about 10 miles approx.
I don't do much city driving in my cars and the only time I have experienced a regeneration was when the sensor mentioned above burned out. I wouldn't do it unnecessarily as your fuel consumption takes a hit each time you force a regeneration. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Well, there are two types of regeneration.
harisson Member Since: 28 Jun 2018 Location: CH Posts: 184 ![]() ![]() |
hi all
so, is the regeneration done due to injection into the exhaust? or does the motor management inject a few times into the cylinder capacity? the injection into the exhaust is the more gentle solution.. Range Rover Sport HST D350 |
I think it’s injected into the cylinder on an exhaust stroke so that it burns whilst being forced into the exhaust raising the temperature and burning of the carbon build up. 2019 5.0 SC SVA (Current)
