![]() | Home > General > Engine Problem TDV8 |
Sorry to hear that. There have been a couple of reports of oil dripping from the airbox after engine stopping and seems to be associated with failure of the turbos. The oil seals had blown allowing oil to flood into the intake side. Probably a wise move not to try starting the engine until further investigation . There is a risk of hydraulic lock and massive engine damage. Check the engine oil level - it may be very low if the above has happened.
chopperchinn Member Since: 28 May 2016 Location: savoie Posts: 26 ![]() ![]() ![]() |
Cheers, same as mine |
Bulldog Member Since: 11 Jul 2013 Location: Solihull, West Mids Posts: 112 ![]() ![]() ![]() |
turbo has failed and pulled oil from engine. do not run as you will hydraulic engine. |
