![]() | Home > My Range Rover Sport > D4 screen |
Here are a few pictures of my newly fitted D4 screen in my sport
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
Is it an easy upgrade? |
Not to bad easier second time around used the guide from disco 3 site and adapted it a bit |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
Has the map update issue for these screens been solved? Regards etc.,
Hi yes I did it for the reverse camera and I think the graphics are much nicer and no I don't think the map issue has been sorted but not bothered up them as yes they are functional but I got a tom tom which is far superior to the out dated Land Rover ones |
Has anyone tried to get digital tv on these screens or which pins they would be as i have a rosen tv set up in the rear the dealer fit type but no tv in the front |
Digital TV comes with many of the systems as standard, I have it.
Yeah i know about the draw backs with the tv but mine is not a standard system as fitted by land rover but as an aftermarket part and the screen is from a 2011 sport and my tv is aftermarket set up and i just wondered if anyone new which pins on the back of the D4 screen were used for tv as i thought i may be able to watch tv on the screen at the front if i new the pins. \the same as i did for making the rear camera work on the screen |
Any one have any ideas |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
So what parts do you need to source to do this conversion? Just a screen like this???? |
have a look on disco3 it is probably easier to do there is not a lot you need just a gps cable extender an ariel extender its easier to look here |
