Home > Maintenance & Modifications > Troublesome brakes |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Sorry to sound harsh, but it sounds as though your brakes need to be properly overhauled.
Fri Jun 09 2017 8:15am |
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 |
Thanks for the advice, I agree it hasn't had the best maintenance. The old callipers were corroded and a lot of the chassis is corroded too. |
Fri Jun 09 2017 10:35am |
Perhaps the car has been standing for some time, which would explain the corrosion. A programme of overhauling the brakes, replacing discs and pads and freeing off the calipers should see you right. replace the brake fluid too!
Fri Jun 09 2017 10:50am |
It's had 2 new front pads and new wheel bearings. Handles much better. Hopefully that's the last of the maintenance for now as this year I've spent 1000s!! |
Tue Jun 13 2017 2:13pm |
Good that you have got it sorted out. The wheel bearings do seem to have a finite life. I replaced both front wheel bearings on mine in close succession at just over 100,000 miles. It is easy enough to do however. |
Tue Jun 13 2017 2:17pm |
Driver side required a lot of encouragement to come off and I mean a lot.. the passenger side came off quite easily. I paid 92£ each. |
Tue Jun 13 2017 2:22pm |
That sounds very reasonable. The difficulty with removing the wheel bearings is that the hub containing the bearing is held on with 4 bolts. Two of them are excessively long and the thread sticking out the far end corrodes making them very tight to wind out, no matter how much you clean them up. New bolts usually come in the kit.
Tue Jun 13 2017 2:25pm |
They were full of dirt and corrosion. Previous owner was a dairy farmer if memory serves, so I can imagine the filth it endured.
Tue Jun 13 2017 2:28pm |
That sounds like very keen prices. Do ask your friend to check the metal brake pipes above the rear axle line at some stage. It is common for them to rust out there. |
Tue Jun 13 2017 2:55pm |
Good advice. Thank you. |
Tue Jun 13 2017 3:20pm |
