![]() | Home > Technical > Condenser change help. |
Remove the crash bar it is only 8 bolts i seem to remember |
http://www.rrsport.co.uk/forum/topic44872....=Condenser
zetecor Member Since: 24 Apr 2017 Location: isle of wight Posts: 20 ![]() ![]() ![]() |
I am so close, mine has the aux rad in front of the condenser. I have removed the main slam panel and the lower crash bar. There is a bolt on the bottom left of the aux rad which is hidden behind the bracket that the lower crash bar was fitted to. Just cant get to it to be able to bring the aux rad forward. |
Got a photo might make it easier |
Thanks, here's a pic of the hidden bolt, I have taken pics all the way and will create a thread when done. I only work in a shop so if I can do it anyone can!
Managed to do it by cutting the dryer off, gave me access to bolt . |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
Good work |
Cheers Phill, just got to reassemble now, I will create a thread with what I done if anyone would be interested. |
Nico2104 Member Since: 10 Jun 2017 Location: Derby Posts: 56 ![]() ![]() ![]() |
Hi mate. I would be interested in you going through what you be done as I need to do the same in my rrs s/c. Cheers |
OK Nico, will do mate, going to reassemble all on Friday.
Cheers mate. Any help would be appreciated. I've also got to fit a air-conditioning pump so looks like it will be a fun weekend for me. Cheers |
Finally done it:
