![]() | Home > Technical > Denso Alternator Fitted But Still Charging 14v |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5038 ![]() ![]() ![]() |
The battery earth is bolted to the inner wing, and there have been instances of them coming loose |
Behind fusebox.
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Is it accessible without moving the fuse box or do I have to remove the fuse box out of the way, if so any recommendations to how? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
I think you just need to remove the battery |
So Ive found were the battery negative wire bolts onto and looks like i have to remove battery and also move the fusebox but while I had the battery cover off I thought id check the battery again with the multimeter and its seems ok again charging at 14v and also 14v with a full load including lights, fans, heated seats its still keeping up charging 14v so now im really confused as I havent changed anything |
360 Member Since: 02 Aug 2013 Location: kent Posts: 116 ![]() ![]() ![]() |
I would stil clean all the earth straps and check all tight, as if intermittent it suggests something loose / corroded |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
It's actually one of the easiest preventative things to do on a car as over time they 'will' corrode, it's just a matter of when. I've made a 20+ year career (non vehicle) chasing earth/grounding problems which with fancier electronics are more susceptible to the problems caused by poor connections. Just for the sake of adding a smear of copper grease, preferably to a split connection then re-coat after connecting. Also if there are any exposed spade connections like switches/sensors underneath then do them aswell, but if there's a concern of short circuiting then choose a dielectric grease - I usually coat my trailer and caravan light connections with this stuff which prevents corrosion at the bulb and other connections. Just slap it on as it has several thousand volt insulation. And top tip - DON'T abuse that old favourite WD40 - I've had it smoking in my apprentice days when trying to dry out an explosion proof light fitting which had filled with water so I was trying to dry out the terminations (yes it should have been isolated...). I learnt quickly that it is not electrically isolated liquid as I was frantically wafting the smoke fumes away from the fire & gas detection systems nearby which if set off would have probably lost me my job! And for the record, WD40 is ![]() 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 36 ![]() ![]() ![]() |
The alternator will charge at an higher rate for the first 3 minutes after start up and then drop back to lower volts, it will also charge at an higher rate in winter when very cold, hence the 15v plus voltage rates reported. The only accurate voltage check is with a multimeter across the battery terminals. You have checked the battery to body earth, but have you checked the body to engine earth and the alternator connections? I regularly get over 15v in winter but in summer 13.8/9 is the norm. ![]() |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
For what it's worth my dad , who was someone I held as very knowledgeable on all things mechanical and electrical used to say a battery (lead acid) shouldn't be charged at higher thank 14.5 volts so if I've got one on the bench I stick to that rule .
gizze Member Since: 31 Aug 2014 Location: Norfolk Posts: 4 ![]() ![]() |
If you have the suspension fault etc. coming up are you sure you haven't got a drain from something?
