Home > Maintenance & Modifications > Oil change, TDV8 |
I suspect that the oil that you put in is a "low ash" oil for cars with a PDF, so they don't have so many auto regenerations of the DPF. While not being either a mechanic or an oil expert, I would imagine that so long as the viscosity is not thicker than the recommended oil you will OK to drive around for a few days until you can drain it and put in the right spec - I wouldn't go to a race track and welly the engine or put it under high load though while you wait to carry out the change. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Jun 03 2017 11:27am |
Edfors Member Since: 11 Oct 2013 Location: Uppsala Posts: 4 |
Yes, both drain bolts are the same and no immediate rush to replace the oil. |
Sat Jun 03 2017 11:43am |
hannez82 Member Since: 17 Apr 2016 Location: VG Posts: 9 |
Thank you for fast answers.
Sat Jun 03 2017 1:16pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
you can use 913C without any problem. this is in fact a mid saps oil (c2/c3) which is of a better quality (higher TBN), but has more ash 0,8% (934B 0.5%)
Sat Jun 03 2017 3:26pm |
