![]() | Home > Technical > Denso Alternator Fitted But Still Charging 14v |
I am not sure what your actual problem is - the charging rate varies depending on the circumstance - mine straight after start is up around 14v to get the charge used on start back into the battery but after the car has been running for a while the charge may go down to about 12.8 but go back up if I turn a few things on like lights etc. 07MY RRS TDV6
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Oh ok I just assumed it was charging low as Ive read a few threads on this forum that charging around the 15v is the norm |
Mine runs at around 13.4 to 13.8 my disco 3 used to charge at about 15 and then drop to about 14 but that was diesel and my sport is petrol which i believe do charge differently |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
14v sounds perfect |
Just been out to check the battery volts just now as ive been having suspension faults message and a low battery warning on my radio display and its now reading just over 13v and 12.5v with lights and fans on, definitely not pleased |
What make alternator was fitted |
Denso brand
I dont believe the system has to be reset - maybe on the later models but as far as I am aware certainly from my 07 and earlier not needed.
I checked the battery before fitting this alternator and bought a new exide battery of the tanya website recommended by a lot of members on this forum, that was the first thing I changed as it was the cheaper option, then changed the alternator as my previous alternator was only charging upto 12.8v even with a new fully charged battery.
You could do with speaking or send a pm to robbie who is on disco3 more than here he knows a lot about batteries/alternators here's a post he did |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Have you already checked the chassis earth connections? I'm not familiar with them on the RRS but it's always my first port of call for charging or slow cranking issue's.
maybe disconnect the battery and give it a charge over night to ensure it's tip top charged after the alternator issues |
Tbh it does sometimes crank slow but only sometimes and thats even when starting after giving the battery a full charge as I normally have my ctek charger on if I know I wont be driving it for more than a week just to keep the battery topped up. The earth wire is quite short so im assuming I should be able to remove the battery and should be just underneath or can anyone confirm if I need to remove any covers etc to get to the chassis connection? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
That was the first thing I did even though I knew the battery is good as fitted a new battery same time as the alternator and did fully charge it before fitting and have used the car more or less every day on mainly long trips. These little gremlins are starting to bug me now, exciting times ![]() EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED, BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR |
