Home > Technical > DSC Issue
Burns
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
DSC Issue
I have a weird issue with my DSC, when pushing on and I steer to the right the DSC operates on my font left wheel.I have recently upgraded my lower font wishbones and had them fitted with polybushes. I drive the same road every day and know it well and the DSC has never operated before but now it does.
Can polybushes cause this or has a sensor or something been damaged during fitting ? Any ideas would be much appreciated. Diesel sport BAS remapped by Bodsy
390 Bhp SLK 55 AMG
H D Softail Slim Milwaukee 8
I like ā€œVā€™sā€ šŸ˜Ž
Post #527416 Fri Jun 02 2017 7:48am
Paddi
Did you have a full four wheel alignment carried out at a centre equipped with Hunter kit after the suspension work?
Have the speed sensors checked for identical live values using a diagnostic tool? 2008 MY Java Black TDV8 HSE
Post #527457 Fri Jun 02 2017 4:45pm
Burns
Solved, low tyre pressure at rear due to slow air leak. It's now been repaired and the problem has gone. I didn't realise the system was so sensitive šŸ‘šŸ» Diesel sport BAS remapped by Bodsy
390 Bhp SLK 55 AMG
Post #527800 Thu Jun 08 2017 4:43pm
