Home > Faults & Fixes > Windscreen top edge finisher fell off
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Anyone had this issue?
Hit day of course, but driving along and the black top edge finisher fell off. Luckily was able to retrieve it.
Shoukdnt this edge finisher be glues in with the pu used on the glass? Might be the car has had a replacement windscreen? Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #526789 Thu May 25 2017 4:31pm
chilly
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
yep passengers side on mine decides to pop all but the bottom fixings while i was doing 70 on a duel carriage way and then proceeded to flap round bouncing of windscreen and bodywork as i pulled over , thankfully no damage done had to replace clips at about 12 quid only the dead truely know peace,
Bootneck its not a job its a way of life!
Post #526807 Thu May 25 2017 9:29pm
If you are referring to the rubber strip that runs along the full width of screen, on a new screen it is just stuck on the top edge with 3M tape and just a new rubber from L/R comes with the tape stuck in the recess which fits over edge of screen.
I don't see any reason it can't be stuck in place using adhesive like STC50550 would stick like s**t to a blanket.
Post #526808 Thu May 25 2017 9:47pm
chilly
I miss read on mine it was the black plastic trim along passenger side edge. only the dead truely know peace,
Post #526812 Thu May 25 2017 11:39pm
Had that problem after new screen fitted, new clips sorted mine as well.
Post #526813 Fri May 26 2017 4:24am
Bigbore
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
+1 RRS SDV6 HSE Orkney Grey,Premium Ebony Black leather,MY12 Autobiography Exterior Design Pack,22"Diamond Turned Rotor Alloys,interior LED's/Number plate,boot LED's x 2,rear entertainment,HD Dash cam,ALIVE Remap,Bumper DRL's
Post #526815 Fri May 26 2017 5:03am
