Home > In Car Electronics > Bluetooth Connection
hutchy
England 2005 Range Rover Sport TDV6 HSE Java Black
I have a 2005 RR Sport and the phone will not connect via bluetooth, it used to but has now stopped.
Do i need to replace the bluetooth module and if so is there a newer unit which is compatible and will download the phone book as well to allow use of the steering wheel controls.
Post #526584 Tue May 23 2017 9:03am
TheWojtek
You did search the forum, didn't you?
http://www.rrsport.co.uk/forum/topic27997....=bluetooth Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #526585 Tue May 23 2017 9:12am
geoffsnook
You can put a D4 bluetooth module in there ask geoff. wiggs on disco3 the can supply them or supply and fit Thumbs Up
Post #526611 Tue May 23 2017 3:47pm
Bodsy
Site Sponsor
If you use code 2121 then I can provide a software updated version which also gives you phonebook on the radio. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #526612 Tue May 23 2017 4:03pm
