Home > Technical > Hard reset!!! |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Join them together after removing cables from the battery - they only need to touch and do not need to be held for 20 minutes. The purpose is to remove any stray voltages in the system that may be keeping any memory alive.
Tue Aug 06 2013 1:08pm |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
many thanks |
Tue Aug 06 2013 2:03pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
Sorry to re-awaken such an old thread but I'm thinking of doing this on my 2010. Like Garry said, it's the same as doing a full shut down on a PC to clear the memory.
Mon May 22 2017 1:25am |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 311 |
Troubleshooting only. No need if everything is working properly. |
Mon May 22 2017 9:13am |
I agree - not needed unless you have a niggling problem that will not go away. It is simple and no cost so has always got to be the first action to attempt to fix an issue.
Mon May 22 2017 9:54am |
Thanks guys..... for the longest time I've had the Extended mode issue where the car thinks there's an obstruction under the chassis when I go into access mode and I have never tried this. Do you think this may help? I'm thinking, "wouldn't hurt to try." |
Mon May 22 2017 7:14pm |
I dont think it would help but wont hurt.
Tue May 23 2017 1:53am |
Mine does that occasionally, according to the garage it's a slightly dodgy height sensor issue.
Tue May 23 2017 3:11am |
The IIDTool makes it pretty easy to recalibrate. I did a quick recalibration a few weeks ago with my IIDTOOL but I'm not sure if I did it to the letter so as to get everything back to stock. I just looked at what I had and made the front ones even and then the back ones even although slightly higher. I tried to find a "reset to factory specs" setting but there isn't one. I'll try again today.
Tue May 23 2017 11:21am |
Ok I just did it and I think I gained an extra 200hp |
Wed May 31 2017 7:52pm |
